Hi Guys,
Is there anyway i can make the railing continues from ramp railing to ist storey railing. Which means i dont have two baluster railing at the corner just only one.
Please fine enclosed.
Thanks & Regards.
You should be able to do it but you would have to first edit the ramp railing sketch path [which is hosted to ramp], and then some additional lines to the railing sketch to simulate the same condition.
1. Add railing > Edit the path > add new segments.
2. Set the new railing path sketch lines from By Host > Flat.
I have included a simple video example below:
Thank you,
