Rail Structure profile coarse/medium/fine detail level problem
2 REPLIES 2
chad2472
755 Views, 2 Replies
Hi Everyone.
I am trying to create a custom railing family that displays different in the coarse detail level than it does in medium or fine.
What I am doing is I have to have a simple line style for the handrails when in fine, and a complex style in medium or coarse.
So I was able to do this just fine with the rail Balusters. I inserted a narrow "Simple" model objects for the fine detail and fully details model objects for medium and fine.  This worked great.
The issue I am having is with the rail structure profile. The horizonatl rail is round. But I want a diameter of 1mm for fine and a diameter or 48mm for medium and fine.  If I place two seperate circles and assign them the "Visibility/Graphics Override" the family brakes and won't let me select the family in the "Rail Structure" of the family type properties.
Any help would be greatly appreciated. Thanks Chad
2 REPLIES 2
Alfredo_Medina
in reply to: chad2472
I think the reason is because balusters are 3D, while rails work with profiles, which are 2D, and if you put 2 circles in a profile, Revit will issue an error, saying that "Rail profile must have one closed loop".
But, just curious, why do you want to have a round rail that is 1mm in diameter? That is a big difference from 48 mm. You might not even be able to see it on the screen, or to build it in reality.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
chad2472
in reply to: Alfredo_Medina
Hi, thanks for the responce. We are just switching over to 3D from 2D and the standard was to show centerlines for the handrails.  So I have setup my handrails with 1mm dia to reproduce the centerline look. But I was hoping to have the option to show the true 48mm rails in the fine detail view.  I don't suppose there is a way to have the dia of the circle change according to the detail level is there?
Thanks Chad
