Radius Wall Sweep
5 REPLIES 5
dylanyoungmandolin
630 Views, 5 Replies
Radius Wall Sweep
I was wondering if anyone has a trick to get a wall sweep on a radius wall, similar to the picture below? Thank you very much.
5 REPLIES 5
Please find the attached file for your query.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Thanks Subhradeep Sen,
but i didnt catch the method as to how you created the sweep?
It looks like a model in place wall. Created with sweep.
Thanks for your reply. It is very simple work. First of all just create a wall. Then edit its profile with "Arc Shape". Then create a Sweep by "Create in Place" option. Through this process just study my Revit file which i have already sent to you earlier.
If i have solved your problem then please send me Kudos & accept it as solve.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Thank you much, its working now
