I was wondering if anyone has a trick to get a wall sweep on a radius wall, similar to the picture below? Thank you very much.
Solved by subhra_civil. Go to Solution.
Please find the attached file for your query.
Thanks & regards,
Subhradeep Sen
Kolkata
India
Thanks Subhradeep Sen,
but i didnt catch the method as to how you created the sweep?
Thanks for your reply. It is very simple work. First of all just create a wall. Then edit its profile with "Arc Shape". Then create a Sweep by "Create in Place" option. Through this process just study my Revit file which i have already sent to you earlier.
If i have solved your problem then please send me Kudos & accept it as solve.
Thanks & regards,
Subhradeep Sen
Kolkata
India
