wow, that is a lot of discussion about everything but the ribbon interface 🙂
I think the interface has potential, but the following are my main gripes
1) The application menu seems to be more complicated - maybe it just takes longer waiting on the flyouts to come up, but I seem to remember save as and exporting being fewer clicks.
2) There is no consistency on ribbon icon locations. why does the properties button have 3 different locations? context sensitivity is great, but you can have both. The buttons should have a global hierarchy that would have properties always appearing on the far left end (....then Filter, etc.).
3) I am not a fan of the way several buttons have been combined into one with a fly down. Mirror is now two seperate commands and the only way to get to Draw Mirror Axis is through the pull down (or defining your own short cut). What was really wrong with selecting the command and then selecting wether you select or draw the axis? The same is sort of true with Element and Type properties, but at least you can get to Type properties the old fashioned way if you click on the Element Properties button by mistake (not the fly out arrow). Those Ribbon buttons sure are big and harder to miss, but when you have to hit that tiny arrow that is half the size of the old icons in order to access a command, is that really an improvement? Maybe they could have had slightly smaller buttons and had one for each command.
I am curious how many users are using Windows XP. The reason I am asking here is we have been having many problems with 2010 running on XP. I just disabled the new interface (against my better judgement) on one of my users machines and his problems seem to have gone away...hmmmm... I'm just curious, but I suspect the Ribbon and XP aren't getting along (and may never).
