Solved by jaredW2GZW. Go to Solution.
Hey Scott, if you look closely, I don't think you answered the question on this thread. I have the same question. It's understood that loading a Curtain Wall Mullion Profile is required in order to create a mullion and that more steps are required after that. The question is, how to troubleshoot this issue, if after loading the correct type of profile from the libraries when initiating the create Curtain Wall Mullion command an error message continues to pop up suggesting appropriate profiles are not loaded. Have a look at the attached image, the system standard Curtain Wall Mullions show in the project browser, however, the message still appears. I also created a new family starting with the "profile mullion.rft" and when I loaded it into the project Revit filed the family under profiles, not under curtain wall mullions and the same error message persists. Do you have any suggestions?
The issue is that you don't have any Types created for any of those loaded Families. Right click one of those Curtain Wall Mullion Families > New Type.
same problem in my project and i don't have a solution to create a new project
if any solution to pleas suggestion me
Look in the Project Browser>Families>Curtain Wall Mullions. There should be Circular Mullion, L Corner Mullion, Quad Corner Mullion, Rectangular Mullion, Trapezoid Corner Mullion, and V Corner Mullion. On one of these families, Right Click>New Type. Now you can add instances of that new Mullion Type to your Curtain Wall either by placing them manually, or by setting them as the Mullion Type in your Curtain Wall's Type Properties>Grid 1/2 Mullions>Interior/Border 1/Border 2 Type.
Let me know if this helps.
