"F" Window on Startup Revit 2014
10 REPLIES 10
Message 1 of 11
bennie
2247 Views, 10 Replies
I recently installed Revit 2014 and I was just wondering what it might be but when I start up Revit whether it is an existing project I have been working on or a new project, a random box appears with an "F" and an Exit button.
It doesn't actually cause any sort of dysfunction or anything, and when I exit it it just goes away. It's just very strange as I don't know what it is, I can't enlarge the box or do anything with it. It's just a little irritation I guess.
Anybody know anything about this?
Tags (4)
10 REPLIES 10
Message 2 of 11
scott_d_davis
in reply to: bennie
its a setting of your graphics card that keeps windows from opening off screen.  This little dialog box is normally hidden, but something in your graphics card settings is forcing it to appear.
Check your graphic card settigns and look for something like "keep windows from opening off screen"
Scott D Davis
Sr AEC Technical Specialist
Message 3 of 11
atiefenbach
in reply to: scott_d_davis
I'm gettting this error in Revit 2012 and Revit 2013 whenever I save or open.  It's not just an "F", it's "Family".  I've tried searching for the "keep windows from opening off screen" setting in our ATI graphics card drivers, but no luck.
I'm also posting the message on ATI's website because we've gone through everything possible to correct the issue.  Any additional support would be great!
Anthony Tiefenbach
BIM Manager
HuntonBrady Architects
Message 4 of 11
bennie
I also went and looked for that option. But nothing in ATI Catalyst.
Might it be something to do with ATI? I am planning on upgrading my GPU this week, but going for an NVidea card this time.
Message 5 of 11
Joe.Charpentier
in reply to: bennie
If you have an ATI card, try disabling/turning off Hydravision.
If you have an nVidia card, turn off the nView desktop manager.
That should stop this from happening.
Let me know if it helps.
Joe
Message 6 of 11
felicity.mills84
in reply to: bennie
I've got an ATI graphics card and having the same problem.  I had it in 2013, but could double click it to make it go away.  Now if I double click it, it says 'encountered an improper argument'.  I have updated the driver, and uninstalled hydravision, but still having the same problem.  Help?
Message 7 of 11
bennie
in reply to: felicity.mills84
I have since I got this problem the first time, gone to nVidea, the "F" block is not there anymore.
I cannot confirm however if there is a direct link between my previous Ati card and the "F" block.
Your problem seems more elaborate than what my frustration was. Good luck!
Message 8 of 11
mike.diaz
in reply to: Joe.Charpentier
Disabling Desktop Manager worked for me.
Thanks Joe!
Message 9 of 11
bguhl
in reply to: bennie
I'm running Revit 2014 w/ATI video card. Disabling Desktop Manager worked for me.
Message 10 of 11
conormccartney3897
in reply to: bennie
For ATI Cards, its not desktop manager specifically, its "Enable Dialog Repositioning". If you turn off desktop manager (my machine at least) re orders all my desktop icons after reboot.
Message 11 of 11
kjohnson
in reply to: bennie
I just got a new computer for work and had the same problem and this is what I did,
I went to the video card (AMD FirePro Control Center) and under HydraVision I went to Dialog Control and unchecked the Enable Dialog Repositioning
And that took care of the problem.
Rail Community
