Structural columns are exported as blocks to DWG, even if I have checked the "Always export as geometry" -box in the column family. Any ideas what's causing this?
Solved by Alfredo_Medina. Go to Solution.
How do you want the columns to be in AutoCAD? It seems that this option of "Export as geometry" does not refer to the exported drawing being a block or not, but it refers to the column being converted to the equivalent structural object in AutoCAD Architecture, or passing as simple lines.
Thanks for answering! That explains why. Actually the real problem here for me is not whether the columns are blocks in the dwg or not. What I'm trying to do is to get the structural column cut pattern and the cut line to separate dwg layers, following the advice about layer modifiers given in this thread: http://forums.autodesk.com/t5/Revit-Structure/Export-to-dwg-column-hatches/td-p/3804025 . I just haven't found the type of layer modifier, that is described in the post...
It works for me. I did not have to go into the families to change the default settings of export as geometry. I just put these settings in Revit. (I exported to dwg from a 1st level plan, with detail level set to fine, so that I could see the patterns). Hope it helps.
That's exactly what I'm trying to do! Could you tell me which layer modifier you used?
It is as shown on the image above, highlighted in yellow, in the Export dialog box. I added "-PATT" to the layer name "S-COLS", (just typing in that cell), and then I changed a couple of colors, that's all. Nothing complicated.
Thank you! That was great.
Any ideas about walls? I cannot get the wall outline and fill to show up on separate layers.
