Quick Drawing in Revit!
1 REPLY 1
Ferrari_Italy
148 Views, 1 Reply
So Revit, for 3D design purposes, is excellent and will probably expand over the 5% usage the recent IT survey in bd's eArchitect supplement suggests. The question is; Can you throw a quick external structure together (similar to Microstation's linear form tool) that you can apply a render to a present or is it a case of creating your wall family first with the different panels and construction already predefined?
Advice would be greatly appreciated!
Paul
1 REPLY 1
in reply to: Ferrari_Italy
can you post an example/image about what you want to achieve or and how does Microstation do it? sorry for my ignorance, havent seen how Microstation works ( is it Microstation or Triforma?) thanks tat "Ferrari_Italy" wrote in message news:15458908.1095411025299.JavaMail.jive@jiveforum1.autodesk.com... > So Revit, for 3D design purposes, is excellent and will probably expand over the 5% usage the recent IT survey in bd's eArchitect supplement suggests. The question is; Can you throw a quick external structure together (similar to Microstation's linear form tool) that you can apply a render to a present or is it a case of creating your wall family first with the different panels and construction already predefined? > Advice would be greatly appreciated! > Paul
