Hello Revit Experts - I'm pretty new to doing IT support for architecture and had some questions about how a Revit server should be setup. I would very much appreciate any assistance with the following:
1) We have two locations about 30 miles apart connected with a 10mb MPLS WAN. It's a small company so we might have maybe 4-5 people working on any one Revit project simultaneously. Revit files are currently hosted at both locations on standard Windows file servers and there is frequent collaboration between employees at both sites. Considering this environment would it be best to install the host, accelerator, and admin roles at both sites?
2) Revit Files are currently saved along with a multitude of other project related files in nested folders. How do I get these existing project files to show up on the Revit server? Can I link to existing Revit files on the file server or must the Revit projects all be hosted on a local drive on the Revit server?
3) Can the host and accelerator roles be on the same server?
That's it for now, thanks in advance for any assistance!
HI Dan,
Here are some answers to your questions:
Answer: If you have a BIM Manager for each site that wishes to perform Admin level work on the Revit Server, then having Revit Server installed as a Host, Accelerator and Admin on both locations is ideal. If you only have one BIM Manager, usually the Revit Server is installed as Admin on one location.
2) Revit Files are currently saved along with a multitude of other project related files in nested folders. How do I get these existing project files to show up on the Revit server? Can I link to existing Revit files on the file server or must the Revit projects all be hosted on a local drive on the Revit server.?
Answer: In order to take existing Revit Central Files and move them to the Revit Server, you will open the Central File as normal then save as a new Central model within Revit Server from within the Saveas dialog box (lower left corner). The default location of the Cache and Projects folder for Revit Server resides within the main root of the hard drive you install it on. It is possible to change this location when you initially install the software. See this link....
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-B4C2C529-26D8-461B-B06A-7E65744A3C72
Answer: yes
Dzan Ta, AEE, ASM, ACI.
Win 11 Pro/DELL XPS 15 9510/i9 3.2GHz/32GB RAM/Nvidia RTX 3050Ti/1TB PCIe SSD/4K 15.4" Non-Touch Display
Thanks for getting back to me so quickly dzanta! A follow up question: The link you included had this to say about updating the path for file storage:
7.(optional) Under Data Storage, If you want to use network-attached storage and have set up a RevitServerService domain user account (see System Requirements), select Store data remotely on a network server, and then enter the domain and password for that account.
Note: If you opt to store data remotely, the paths for the Cache and Projects folders must be fully qualified UNC paths. Mapped drives will not be accepted.
If I choose to keep the Revit files where they are now on the file server and configure the Revit server with the options to access them there, how much of a difference would it make to overall performance? I'm reluctant to move all of the Revit project folders over to a different machine other than the file server as it would split the projects up into different locations (we also use autocad architecture and save projects togther in the same network drive). These project folder also contain a number of nested subfolders with related documents, pictures, and correspondence. How can I keep the same organizational structure as we use now while also using the Revit server?
