So you are comparing the time it takes to get the first Revit project off
the ground to the time it take to do a project in LT when you have years of
project set up already done in LT. That first project in LT took a long time
too since all those details, titleblocks etc had to be created for the first
time then too.
Lance W.
______________________________
my advice is congruent and factual..
"Nathan" wrote in message
news:6344880@discussion.autodesk.com...
> Sorry Matt but you must have been pretty unproductive with Lt!
> Unless OOTB provides you with what you need, just learning how to build
> your own families etc is going to take lots of extra time that it would
> take to draw a project in lite.
> I'm sure he has details, title blocks etc all ready set up in Lt. Not to
> discourage him from diving into Revit but as an outsider looking in there
> seems to be a lot of work getting everything set up as you need to. I
> understand Revit can be very productive but like all complex software it
> will take a fair investment to learn. $ & time.
> "Matt Stachoni" wrote in message
> news:6344702@discussion.autodesk.com...
> Well, on the productivity question, I can offer this:
> If you know and love LT, you can surely be productive with it. But heck,
> you can
> be "productive" with a napkin and crayons if those are your favorite
> tools.
> But if you take the time to learn Revit, you can become AT LEAST as
> productive
> with LT on the first house project.
> After that, you are going to be pumping out houses like you won't believe.
> Why?
> Because residential documentation is extemely repetitive. After the first
> house,
> you've built pretty much all of your your common project standards, title
> block(s), sheets, wall types, levels, view templates, component families
> like
> doors, windows, and cabinetry, roof types, stairs and railings,
> annotation
> tags, schedules, detail components and drafting views.
> You have your project template all set to go. Your next project now starts
> with
> all of that content and formatting complete. That's a huge amount of work
> done.
> Matt
> matt@stachoni.com
> On Wed, 24 Feb 2010 23:52:03 -0800, Tilt441 <> wrote:
>>Some background: I currently use AutoCad LT 2004 to draw (mostly) house
>>plan projects. I'm looking to expand my work, and getting up with some
>>more cutting edge software to increase productivity.
>>I saw a web-cast on Revit today and have a couple questions.
>>Is there a 'built-in' AutoCad ability in Revit? Once you learn the
>>software, can you use it to model a house VERY accurately - and take 2D
>>Elevations, Floor Plans, and Sections from the model (accurate for
>>construction)?
>>I'm very 'behind' with AutoCad - and Autodesk is almost too daunting to
>>figure out what I could use to really increase productivity. As a single
>>person business, I have a hard time getting much info out of Autodesk
>>re-sellers (they only seem interested in the sales to larger
>>corporations).
>>What does Revit Architecture 2010 cost (in Canadian or US)? I've looked
>>all over the internet, and have found everything from $199 to $4000.
>>Thanks,
>>Lyle
