question about the walls
3 REPLIES 3
250 Views, 3 Replies
good afternoon
i have a REALLY strnage matter to ask
i am doing a project that drawing a revit 2013 project over an already autocad drawing
(using walls and picklines)
when i started the Archi project, in the walls there was "Storefront" and "Exterior Glazing"
i imported the CAD file and started to draw, made duplicate of the walls and made my own sizes (everything is duplicated"
i closed the project after almost 3 hours of working
now i opend it again to start working, needed to put "storefront" wall in the building front
only "curtain wall 1" is on the list !!!!!!!!!!!!
how can i find the messing walls !!!
also the basic walls menu has like 5 walls only
where did they all go ?
best regards
3 REPLIES 3
AJA14
The only thing that comes to mind is that you performed a purge all command and you lost all of the unused types.
Try opening a back up to find if you still have a version that has the full data.
Ali Al-Hammoud
Structural Design Engineer
MZ & Partners Engineering Consultancy
in reply to: AJA14
Yes, i made purging
but the problem the backups also has no full datat required
is there anything to do to bring it back
i dont want to start my work again !!
AJA14
I don't think you have an option but to start over. However, my advice to you is to create a template. That way, if and whenever you need anything from the template you can use Transfer Project Standards and transfer what you need.
regards,
Ali Al-Hammoud
