Question about messurements
4 REPLIES 4
376 Views, 4 Replies
Hello you all!
I'm learning to use Revit, so may be this is a Easy question for you 🙂
I'm trying to do some holes messurements and want to put O.K/U.K messurements so I need 2 lines under the line...
Is there any way to do this??
I saw If I click the number I can add 1 line above and 1 under the text, but I need 2 under...
If someone can help me please!!! 🙂
Thank you very much!!
Jenny
4 REPLIES 4
loboarch
This would have to be done manually with a text element.  Even using the line under it will only fill out what you type.  it can't "read" the dimension string and resolve the value.
Jeff Hanson
Principal Content Experience Designer
Revit Help |
Thanks for the answer, I know I can do that with the regular text line, but I'm asking if is there any way to do this as a part of the dimension line so it will move and have the same properties as the dimension line.
Thanks!
Jennifer
loboarch
No it is not possible.
Jeff Hanson
Revit Help |
O.K then, I guess I'll have to keep using a separate text for this issue.
Thank you very much for the answer 🙂
Jennifer
