Pylon for a bridge
4 REPLIES 4
2727 Views, 4 Replies
Pylon for a bridge
Hi
The past few days I've been trying to draw a pylon for a bridge that looks like an A-frame in front view and has an "Λ" shape in the side view. Therefore, I need the pylon to have a curvature in both planes. But, I dont know how because it isn't letting me modify it in two elevations. Is there anything similar out there like a video/ tutorial that can help me do this. If you could please help me, it is urgent!
I've added an image as an attachment for you to see what I'm talking about.
4 REPLIES 4
constantin.stroescu
I think the best method is to do it as a Family - Structural Column as a parametric element and then load it into the project.
The steps:
  1. In Family make first a box by Extrusion with parametric dimensions : Width, Depth, Height
  2. Then in Front View make an Extruded Void to cut after one of the profiles- apply Cut
  3. and then in Left View the other profile to cut the box after the other profile - apply Cut
  4. load the resulted family into the project
My pillar looks very bad...but you have to look at the method....
1
2
3
Constantin Stroescu
I would do this starting from a generic model adaptive template. Some reference planes in plan view determine what is Left, Center, and Right. In elevation, some points determine the path of the arc. The upper points need to be hosted by the Center reference plane, to form a flat arc. The lower points are hosted by other reference planes to form the slanted arcs, or legs. Splines are created following these points. Then a circular profile is extruded, one by one in all the splines. Points, reference planes, and profile could be controlled by parameters, to drive the form.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Hi Alfredo,
I agree whith you ,with only one small change:
You said:
"Then a circular profile is extruded, one by one in all the splines."
I think that it will be bettter to use  a swept blend so to have not only a circular profile but a section that varies in size from bottom to top of the curve ( for instance from a rectangle in bottom to a circular smaller profile in the top...). If this "column" is made of concrete, surely its sectional shape varies from bottom to top
Constantin
Constantin Stroescu
Yes. Once the skeleton is done, the section profiles can vary. Since we didn´t have any information about the section, I used a constant circular profile, as if the arch was made of round steel pipes.
