I WISH TO KNOW IF IT IS POSSIBLE TO SHOW VALUES OF A PROPERTY LINE IN DEGREES MINUTES AND SECONDS BY SIMPLY CLICKING ON THE LINE?IS THERE AWAY OF ANNOTATING ANS INDICATING THE DIMENSION AND ANGLE VALUE AS SHOWN ON CONVENTIONAL SITE/SURVEY PLANS?
THANKS
Solved by ryan.duell. Go to Solution.
You can create a Property Line Segment tag by:
1. R > New > Family > Annotations > Generic Tag > change Family Category and Parameters > Property Line Segment Tags.
2. Add desired label under Home > Label > choose Parameter[s]. Load into Project.
3. Annotate > Tag by Category > click on Property Line
The tag should indicate the value you specified in the Label [in the tag family] and display this in the tag.
Please let us know if this helps.
Thank you,
Is there a way to change the distance parameter in the label to decimal feet eg. 82.00' instead of 82' - 00". I have tried changing the units in the family and in the project but I get the same result. this is the result I would like to have. :[N 18%%d 42' 00" W 82.00'] instead of [N 18%%D 42' 00" W 82' - 0"]
Thank you! I did not know that was there once you highlight the parameter.
