Project information
1 REPLY 1
184 Views, 1 Reply
Project information
Is it possible to add more attributes to the project information dialog box ? my angle is: I want to add revition text to sheets, and I thereby need to set some global attributes with revition text for all sheets. I also plan to add this reviton text by opening revit with a custom journal file. -- mvh Roger Helgesen Helgesen Tekniske-bygg AS 56193410/93463588
1 REPLY 1
Yes. Label->Select->Add and Create a shared parameter... Not sure I'd fool with opening Revit with a custom journal file? Are you trying to automate a plot date or (?) "Roger Helgesen" wrote in message news:410f408e$1_1@newsprd01... > Is it possible to add more attributes to the project information dialog box > ? > > my angle is: > I want to add revition text to sheets, and I thereby need to set some > global attributes with revition text for all sheets. > > I also plan to add this reviton text by opening revit with a custom journal > file. > > -- > mvh > Roger Helgesen > Helgesen Tekniske-bygg AS > 56193410/93463588 > >
