Project Browser sub-categories
1 REPLY 1
joseg
1962 Views, 1 Reply
Greetings,
How can I create sub-categories in the PB. Under "Drafting Views (Detail) / Architectural" I would like to create sub-categories for each detail sheet number. Under these I would then add all the details that belong in that sheet. This will allow me to 'close' sheets so that I'm not displaying all of the details for each project. And once this is done can I transfer this set up to all the cad stations or does it have to be done manually for each one of them?
thanks,
jg
1 REPLY 1
Scott_Womack
in reply to: joseg
Add a project parameter, Instance based, assigned to views. Then set you browser to sort using that parameter as the second or third sorting item.
