Project Browser and Properties Frozen
73 REPLIES 73
Message 1 of 74
68976 Views, 73 Replies
My computer crashed earlier today and since i've started up Revit again my project browser and my properties have become frozen. I can maximize and minimize them but i cant move them anywhere or click on anything thats in them.
I've rebooted and also run a repair but no luck.
I've searched countless forums and cant seem to find anything relating to the problem and revit is unworkable without these 2 items working.
I'm running Design Suite 2014.
Any help is appriciated.
73 REPLIES 73
Message 2 of 74
CoreyDaun
Hello, I can't help much, but I can suggest trying two things:
1. Under Options, try toggling 'Hardware Acceleration' and see if that helps.
2. Try installing Revit 2014 Update Release 1, which is available on the Autodesk Subscription Center.
Good luck!
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
Message 3 of 74
bzuzik
Was there ever any resolution to this issue? I am having exact same issue today
Message 4 of 74
Alaaeldin_Alsahli
in reply to: bzuzik
Revit some how got corrupted. the best thing to do and usually fix it, go to Start bouton and write Regedit
once the registry editor windows opened
fallow this video https://chronicle.autodesk.com/Main/Details/6069434e-3ed2-4a10-b182-a3d16eeb6292
and then reopen Revit
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Message 5 of 74
bzuzik
That worked, thanks for the help!
Message 6 of 74
Alaaeldin_Alsahli
in reply to: bzuzik
no problem please click accepted solution to help others to find it
Alaaeldin Alsahli
Message 7 of 74
in reply to: Alaaeldin_Alsahli
Alaaeldin Alsahi, thanks for that solution!
For those not interested in watching a video, he simply renames the following key:
HKEY_CURRENT_USER\Software\Autodesk\Revit\Autodesk Revit Architecture 2014
to:
Autodesk Revit Architecture 2014 backup
Message 8 of 74
will
Hi- am having the same problem and tried the reqedit fix but it did not solve the problem.  Properties and project browser windows are still frozen.  I am using 2014 Revit LT.  Anything else you can offer would be greatly appreciated.  Thanks.
Message 9 of 74
C.haskings
I have just gone through this issue on 2015.
I tried the 'successful' link and did not get the intended outcome. not sure if the same process for 2015 applys.
The method I used to unfreeze my project browser were as follows:
1. Open 'User Interface' under View tab.'
2. go down to 'Browser Organisation'. This is where I changed a preference. Under the Sheet tab I changed the preference to 'Prefix' ( i'm sure any tick box would event in the same outcome). Apply and OK.
This updated in my project browser which had also unfrozen my project browser . I then went through the same process to change my preferences back.
All working again!
Tags (1)
Message 10 of 74
I had teh same problem on 2015 ur6
Did the Registry Edit & it all corrected
Great tip
Message 11 of 74
geotob
in reply to: C.haskings
Same problem with 2015. Clicking "prefix" worked great!
Thanks C.Haskings
Message 12 of 74
mmorrissette
in reply to: bzuzik
I have also found that if you open a new project for some reason it will unlock the project browser and properties.
Message 13 of 74
in reply to: will
turned off hardware accelation and re-started 2014....YEA!
Message 14 of 74
arask14
This worked for me! Thank you very much for the help.
Message 15 of 74
I know this is almost a year later, but we found that simply opening the options dialog box and closing it again without doing anything in it allows you to close the Project Browser and Properties.   We even have a plug-in that freezes the same way and the same workaround allows us to close that.
If anyone is following the steps from C.haskings (thank you for those, btw), hopefully this will at least save you a few clicks.
Message 16 of 74
petecaistor
That worked for me too. Thankyou very much!!
Message 17 of 74
This techniqe works great! Very easy to do.
Go to UI/Project Browser Organization/Sheets/, put check mark in Sheet Prefix (one other than the current). Come out, windows will be active, then you can go back and switch back to you original setting under Sheets.
All fixed!
Message 18 of 74
mdhutchinson
I think we just had this also... we solved it by going to Options > General... and simply retyped the Username into that edit box.
As soon as we did this... the project browser could be moved again.
Message 19 of 74
NR2015
Thank you
This solution helped for me too
Message 20 of 74
obrill2
Thank you so much for the option you gave! I have Revit 2016 and only under the Browser Organisation steps allowed it to unfreeze.
Thank you again!
