Revit Architecture
Member
ste239
Message 1 of 8 (2,781 Views)
Project Browser and Properties Frozen
2781 Views, 7 Replies
08-27-2013 09:08 AM
My computer crashed earlier today and since i've started up Revit again my project browser and my properties have become frozen. I can maximize and minimize them but i cant move them anywhere or click on anything thats in them.
I've rebooted and also run a repair but no luck.
I've searched countless forums and cant seem to find anything relating to the problem and revit is unworkable without these 2 items working.
I'm running Design Suite 2014.
Any help is appriciated.
Revit some how got corrupted. the best thing to do and usually fix it, go to Start bouton and write Regedit
once the registry editor windows opened
fallow this video https://chronicle.autodesk.com/Main/Details/6069434e-3ed2-4a10-b182-a3d16eeb6292
and then reopen Revit
CADastrophe
Message 2 of 8 (2,740 Views)
Re: Project Browser and Properties Frozen
08-28-2013 09:48 AM in reply to: ste239
Hello, I can't help much, but I can suggest trying two things:
1. Under Options, try toggling 'Hardware Acceleration' and see if that helps.
2. Try installing Revit 2014 Update Release 1, which is available on the Autodesk Subscription Center.
Good luck!
Active Member
bzuzik
Message 3 of 8 (2,281 Views)
01-30-2014 08:53 AM in reply to: ste239
Was there ever any resolution to this issue? I am having exact same issue today
Product Support
Alaaeldin_Alsahli
Message 4 of 8 (2,273 Views)
01-30-2014 11:51 AM in reply to: bzuzik
Alaaeldin Alsahli
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Active Member
bzuzik
Message 5 of 8 (2,269 Views)
01-30-2014 11:57 AM in reply to: ste239
That worked, thanks for the help!
Product Support
Alaaeldin_Alsahli
Message 6 of 8 (2,267 Views)
01-30-2014 11:58 AM in reply to: bzuzik
no problem please click accepted solution to help others to find it
Alaaeldin Alsahli
New Member
ddillow
Message 7 of 8 (1,032 Views)
06-11-2014 05:24 AM in reply to: Alaaeldin_Alsahli
Alaaeldin Alsahi, thanks for that solution!
For those not interested in watching a video, he simply renames the following key:
HKEY_CURRENT_USER\Software\Autodesk\Revit\Autodesk Revit Architecture 2014
to:
Autodesk Revit Architecture 2014 backup
New Member
will
Message 8 of 8 (603 Views)
07-21-2014 05:56 AM in reply to: Alaaeldin_Alsahli
Hi- am having the same problem and tried the reqedit fix but it did not solve the problem.  Properties and project browser windows are still frozen.  I am using 2014 Revit LT.  Anything else you can offer would be greatly appreciated.  Thanks.
