i created the window attached below. Everything is working fine, except that the little triangle above has no glas?
If i insert the family into my project, the three big windows have glas, the triangle not. In the family editor, glas is shown.
What is wrong?
Solved by L.Maas. Go to Solution.
In the project set the detail level from fine to medium, and those triangles will show up.
Louis
Please mention Revit version, especially when uploading Revit files.
I selected the triangle window in the family editor and activated the visbility settings
You can see that Fine (detailed) is not selected.
Louis
