Hi i'm fairly new to Revit and seem to be encountering a problem that wont let me advance with my project.
I am in the process of drawing up an existing building and firstly am setting up with the building mass. I have managed to get the main bodys of the building done and the main roof.
The problem now is that when i switch too the east or west elevations to add mass for the roofs on the adjoining wings of the building it wont let me see the model lines when i draw them in the screen i just get an error message " None of the created elements are visible in Elevation: East View. You may want to check the active view, its Parameters, and Visibility settings. "
I have my reference line set not far from the building and it seemed fine when i done the roof from the north and south views for the main building. I can see the model lines when i switch too 3D views but i cant create the mass from there.
I have attached a picture of what i mean.
Can anyone advise if they understand what i am going on about??
Cheers
Solved by constantin.stroescu. Go to Solution.
Your lines are out of your elevation area:
Constantin Stroescu
