Hello, I have acquired the trial.autodesk revit 2015, and I've installed but not installed so families you uninstall it completely to reinstall it, but in doing so in the installation interface appears as I installed , which is not true because in the control panel does not appear, please if you have any solution
Hola, he adquirido el revit 2015 de trial.autodesk, y lo he instalado pero no instalo las familias asi que lo desintale totalmente para volverlo a instalar, pero al hacer eso en la interfaz de instalacion me aparece como instalado, lo que no es cierto por que en el panel de control no aparece, por favor si tienen alguna solucion
Try to uninstall it using FixIt: Fix problems that programs cannot be installed or uninstalled
Your installation still left in registry and you need to remove it. FixIt will do it easily.
