First thanks to take your time for me,
I had the problem that I have a new laptop but it seems that it have not enought ram space to install all the library, I tried to install everything in a external hard drive but it did not allowed me, so I canceled the family library installation and I install the rest of the program.
I started a Revit course, and I am starting to discovering my mistake, because there are no templates, where the levels and the section does not exist, of course I don't have families, and I don't know what I will discover in the future.
My question is, is it possible to install the library in a external hard drive? Because right now I am trying to do it, but I don't find the possiblity to re-install all the families.
Apart of advicing me to buy a new computer, which right now I cannot afford it, could you give me some advices?
Solved by David_W_Koch. Go to Solution.
Solved by BalajiHTI. Go to Solution.
If you have insufficient local hard drive space to hold the Revit content, you should be able to have it installed elsewhere. I have never tried to do so to an external hard drive, but we have done so to a network drive, which should not be any different. It is definitely possible if you create a deployment, but I believe you can also modify the content location when doing a stand-alone installation.
At worst, if you can temporarily make room to install the files on your local hard drive, you can move the libraries and other content files to the external drive, and then change the locations in the Options dialog.
So do you recommend me to desinstall the Revit, and install it again in a external drive?
That could be one approach. Not sure if you just tried to do a repair installation or a reinstallation over the current one whether you would have an opportunity to redirect the content folders. You will not want to install the entire program on the external hard drive, just the content files.
