Your title will land below the crop region of that view. Turn on the crop
region for the view (it sounds like it's not on) and adjust it to suit.
Your title should now appear much closer to where you need it. You can also
drag the title independently of the view by clicking on the view and tabbing
through your choices until you highlight the title only, which you can then
drag where needed.
"gnikas" wrote in message
news:19136299.1078973521945.JavaMail.jive@jiveforum2.autodesk.com...
> I am having a problem with the View Title description not inserting
correctly when I insert a drawing on a page. At times the title will be well
below the drawing or in the middle of the drawing. Is anyone having this
problem and has anyone found a solution other that moving the drawing on the
working view?
