Hi dear, when I try to create section I see that an object which is behind of the section line appears in the section view.I couldn't find what is the mistake.Do you have an idea ?I am adding 2 pictures which explain my case.Thank you...
THank you for the answer.As ı understand there isn't any technical problem with my section isn't it?
The section works correctly. As I've explained above, the tree is visible, becaouse it's not cuttable, which means that if the section line goes through the bounding box of the 3d element, the whole element is displayed instead of the cut off part.
