Hi guys,
I've got a silly problem with Revit and it just drives me nuts!
it works just 2 or 3 days on my notebook and after that when I want to open it,it shows me this error "this programm doesn't work anymore" and the only way to run Revit again,is to change the windows! I mean it doesen't help when I just unistall the software and install it again,I should certainly change the windows,and till now I've changed the windows times!!!
I'd like to ask if any of you have faced this problem? or probably knows what I should do?
my windows is original and the Revit is a studentversion which I've downloaded from Autodesk...
I'd be really thankful if you could help me 🙂
Unfortunately I do not have a solution for you.
But as mentioned in the first post in the top of this forum it is probably better to post your question in the "installation & licensing forum".
Louis
Please mention Revit version, especially when uploading Revit files.
