Problem with plan view
4 REPLIES 4
451 Views, 4 Replies
Hi guys,
here I marked with red arrow the beam which is going up to 10 m above ground. Under beam there is a wall, the screen shot is taken from ground view plan. Why on ground view plan beam is visible? I thought view is made like cutting 1 m above the 0.00 level
4 REPLIES 4
arunag
Check in View Properties if the the underlay orientation is reflected ceiling plan of Ground level.
Aruna
School of Architecture
Ramaiah Institute of Technology
Bangalore
in reply to: arunag
It does not work. Any other ideas?
jkarben
Is the beam diagonal from the floor upwards to 10m? Typically once a portion of the beam is below the cut plane the entire length of the beam will appear. It might be simplier to hide the element in view.
There is a setting in the beam family that will allow it to be cut at the cut plane height instead of showing the whole length. Uncheck "Show family pre-cut in plan views". Be cautious as this will change the setting for all beams in the family.
in reply to: jkarben
Thanks a lot! It works!
