Hi guys,
here I marked with red arrow the beam which is going up to 10 m above ground. Under beam there is a wall, the screen shot is taken from ground view plan. Why on ground view plan beam is visible? I thought view is made like cutting 1 m above the 0.00 level
Solved by jkarben. Go to Solution.
Check in View Properties if the the underlay orientation is reflected ceiling plan of Ground level.
If so, change it to plan.
Is the beam diagonal from the floor upwards to 10m? Typically once a portion of the beam is below the cut plane the entire length of the beam will appear. It might be simplier to hide the element in view.
There is a setting in the beam family that will allow it to be cut at the cut plane height instead of showing the whole length. Uncheck "Show family pre-cut in plan views". Be cautious as this will change the setting for all beams in the family.
