Problem with PDF and DWG export
2 REPLIES 2
keesmeinders
308 Views, 2 Replies
When I try and export a plan into PDF or DWG the image I get are totally blank. What am I doing wrong?
Thanks in advance.
2 REPLIES 2
hi
Namely, After exporting DWG file is not in graphics?
Please check The layers When exporting .
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
CoreyDaun
in reply to: keesmeinders
Hi keesmeinders, Welcome to the Discussion Groups!
Could you describe the steps you are taking to export your files? This would help everyone get a better idea of what exactly is going on.
Corey D.        ADSK_Logo_EE_2013.png    AutoCAD 2014 User  Revit 2014 User
⁞|⁞ Please use Mark Solutions!.Accept as Solution and Give Kudos!Give Kudos as appropriate to further enhance these forums. Thank you!
