Revit Architecture
Revit Architecture
New Member
wizardry12
Message 1 of 3 (522 Views)
Problem with Joining Slanding Slab with Staircase
522 Views, 2 Replies
07-03-2012 11:40 PM
Anybody can advise on is it possible to join the floor before the staircase and make the profile slanded follow the staircase as per the attached image. Thank you in advance =)
Alfredo_Medina
Message 2 of 3 (507 Views)
Re: Problem with Joining Slanding Slab with Staircase
07-04-2012 09:40 AM in reply to: wizardry12
Unfortunately, stairs and floors still don't join in Revit.
Alternatives:
1) Read about the "Cut Profile" tool. It is a 2D solution for sections. This will allow you to "cut" the edge of the slab.
You might need to do this anyway to fix the floor. Notice that in your section, the finish floor is getting inside the stairs.
2) Do the stairs with a "landing" at the starting level, that matches the floor. Not ideal, either, but, a workaround.
Planta1 Revit Online Consulting | info@planta1.com | my Twitter | The Planta1 Blog
New Member
wizardry12
Message 3 of 3 (483 Views)
07-04-2012 08:09 PM in reply to: Alfredo_Medina
Thank you very much for your reply. But do you know where can I find the parameter 'Start with landing' for the staircase?
:smileyhappy:
