I posted this question in a similar post but the most recent reply was in 2012, so I am reposting here.
I have drawn a mullion profile for both the left and right jambs, it appears correctly in the profile family creator. To do this, I imported and exploded 2 separate CAD details that display in "fine" mode for each profile. Each is oriented correctly in the detail component which is loaded into the profile family, and the profile for the mullion traces those detail outlines to create the mullion in the curtain wall system.
Problem is, while the profile and detail display correctly in the editor, Revit decides to flip the detail on the left side (right displays correctly) when loaded into the project. In the family editor this is not the case. Both jambs appear as they should. In the project however, it doesnt matter which way I draw the wall, or flip the wall, or rotate the wall, the detail is flipped from the actual profile that is creating the model element in the project.
This makes no sense, I have tried recreating everything from CAD, 2 sepearate files for each jamb, imported them into a blank detail component template just to explode, change line types and purge, then copied and pasted into yet another detail component that I load into the profile family for the mullion.
Even after taking all those steps to ensure the detail is oriented correctly, Revit will flip ONLY the detail and leave the profile alone once it is part of the curtain wall in the project. To make this as clear as possible since it may sound a little confusing, the profile is correct, the detail flips itself on the left jamb. This is despite the fact that the detail appears correctly in the profile family editor.
Any solutions for this problem? That seems like a bug as I have done everything possible to ensure the detail aligns with the profile, which the detail does when loaded into the profile family, yet it flips in the project. AND, the detail is made completely of Revit lines, no CAD. Even the CAD I used was exploded in a separate family to convert into Revit lines and pasted into a new detail family that I import into the profile family.
Any ideas for this problem? I'll happily upload if Autodesk would take a look. I've been using Revit since 7.1 and haven't had in issue like this until 2014.
This is an open issue that development is aware of. The work-a-round is to create a profile for the right and one for the left. Hope this helps and thanks for posting.
I have one for left and right. The problem is that the detail flips on one side, even though the profile stays correct. And in the family editor the profile lines align with the detail profile. The problem only occurs once it is loaded into the project. Even then, it sometimes appears correctly, but simply moving the wall to a new location causes just that one detail to flip even though the mullion profile remains correct.
There is not any logic to why this is happening, so I am assuming there is no solution and that as you said, it is an issue being worked on. In regards to your suggestion, to reiterate, I do have a seperate detail for left and right, and each one is loaded into the respective left/right mullion profile.
If you have a plan region in this area, turn it off or shift it away from mullions.... This was causing the detail portion of the mullion to flip 180 and offset.... No idea why.
SixthRiver got it exactly right. As soon as I move the plan region to not include the curtain wall, the mullion looks correct. Very strange indeed.
I want to point out that although it is flipped 180° in my floor plan with a plan region over it, in the enlarged plan, it is oriented correctly. It's an annoying graphical issue that I guess we just have to deal with. I'm working in 2017 and it still isn't fixed.
Yes,
same problem here...
quite arbitrary actually, some work, but one detail flips.
Any news on this?
thanks
regards
gio
Alright,
One of the profile inside a mullion which was flipping now works.
What I did to fix it was tweak the orientation of the section view to become perfectly orthogonal to the curtain wall.
I had to use a rotation plugin that allow you to match rotations of different objects (it's in the app store), because there are no other ways (OOTB) to rotate a section view to match anything, of course.
I have not tried this with other mullions, just one mullion, once, but I think this is a solution, and I wanted to see if other users would solve their flipping by aligning their sections more precisely (in my project, I have weird, irrational angles for three out of 4 walls of the building...).
regards
gio
