I'm trying to filter out the doors so that only 36" doors are heavy lines.
When I do this, I have to select (none) un the "filter by" portion of the
window for all other fields. I'm ok with that.. the problem I have is that
it will not stay that way.
I select none for them all and click my OKs. When I apply the filter in
another view it does not work.. at all. Nothing changes.
So I went into my edit filter window... and the values changed from none to
"#" which is the top of the list.
Please help.
Thank you.
