When I export to CAD formats, 1 Dimension Style in Revit is automatically duplicated to many styles in Cad.
I knew that because I moved the text of dimension to another place in Revit. But I don't know how to solve it.
Is there any way to reduce the Dimension Styles down?
Please help me.
Thank for your regard!
Thanks for your help!
I tried it but it didn't work.
In a new file, I've just use 1 dimension style.
In picture 1, I didn't do anything with dimensions. Then it's ok in cad format.
But in picture 2, I moved the dimension text to another place. And then, in cad format, it automatically duplicated to many dimension styles.
It's really troublesome if there's a lot of dimension styles in cad.
is there anyway you can send me the files to check im my email add. thanks
hi , sorry for late reply. i already send the solution to your problem thru your email add including the test files. hope in helps. thanks and regards.
Thank for your reply!
You meant that in revit I shouldn't do anything with the dimensions? But if I don't move the text, I can't see the number clearly.
So there is not any way to solve it? Thanks a lot!
hi, i didn’t not say you can’t do anything with the dimension in Revit, yes you can. No solution yet at present time for this problem ( i guess). When you exported into AutoCAD select all the dimensions and change to one dimension style solve your problem and then purge to delete all the dimension style you don’t need.
Thanks and regards.
