Problem with curved wall of the shell
2 REPLIES 2
GHASEM_ARIYANI
407 Views, 2 Replies
Hi
I have a problem with a picture that I've attached here.
I made the curved wall and the wall directly into the shell and got out of it was drawn.
How do I delete these extra parts.
Thank you, I have answered.
Perhaps the problem is that many people work with Revit.
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
2 REPLIES 2
Using the same curve that generated the curvy wall, create a void, and cut the straight wall with that void.
Licensed Architect (Florida) | Freelance Instructor | Autodesk Expert Elite (on Revit) | Profile on Linkedin
Hi
  Thank you for your answer.
I do it but I do not exact
Because of the low wall above the curve moves.
Please if you can further explain or movies and photos can be provided.
Ariyani
