Problem with adoptive element to solve
3 REPLIES 3
pasterski.k
261 Views, 3 Replies
Hello guys, anyone has an idea why i can not to sweep element i created? Pic below. Thanks a log.
3 REPLIES 3
Revit won't create geometry that is self-intersecting. Assuming you want a profile to follow that path, it crosses over itself.
My other older self here: http://forums.autodesk.com/t5/user/viewprofilepage/user-id/46056
And what about that? I did it 2 hours before. It cross. Sorry for camera.
That's not the same path as the first image though. If it isn't complaining about the intersection (which Revit generally rejects too) at the midpoint then it's the endpoint where it can't close the shape? That's my guess at this point...
