Problem: visibility of a beam in plan view
1 REPLY 1
791 Views, 1 Reply
If i draw a beam in plan view en define the height, the beam disepare. Is there a posibility that the beam is in place and you can see a dash dot line and two dashed lines in plan view?
thx
1 REPLY 1
mike
Most likely the beam level is above the view cut plane level. If you put in a plan region where the beam is located ( View tab / plan views / plan region ) and set this cut level to be through the beam, you can then see the beam.  You can then use the linework tool to get a dash dot line or however you would like it to display.
