Problem printing PDF using Revit 2013 & Windows 8 - 64bit, please help!
3 REPLIES 3
mouleepatel
988 Views, 3 Replies
I am trying to print PDF's of my sheets on Revit 2013.  I have a windows 8 laptop, 64 bit.  It is not doing anything, not creating the pdf when I click print.  Please help, all suggestions welcome!
3 REPLIES 3
edwin.prakoso
in reply to: mouleepatel
I'm not sure if this is another compatibility issue Revit 2013 and Windows 8.
Just to make sure, try to install Revit Update release 1 and 2. After installing it, check if the problem persist.
If this post solves your problem, please mark it as solved. It will help others with a similar problem to find a solution.
Kind regards,
Edwin Prakoso
LinkedIn | Website | Twitter
Jason_S
Update 2 for Revit fixed this issue for me.
pmoyer44
in reply to: Jason_S
I installed update 1 - 3, and hotfixes and I still have your problem.  Are you using Adobe Acrobat Writer?  Is any one using BlueBeam without problems?
Rail Community
