Hello there,
can anybody detect why I fail to insert the attached family into a wall? I get an error message but fail to discover the it's source.
Solved by L.Maas. Go to Solution.
I did a quick check. Could not determine the cause.
Noticed that when deleting all dimensions and reference planes (except the template ones) from the family I can insert it in a project.
So I would try to remove all these dimensions and reference planes, test it in a project and then step by step put back in your constraints.
Louis
Please mention Revit version, especially when uploading Revit files.
