Hi, can somebody help me with the problem that im having? im trying to delete a column and it doesnt allow me to it.
here is the link of a video:http://screencast.com/t/jFvqZmnSd
thanks.
Solved by ennujozlagam. Go to Solution.
I had before such kind of problems when ,by mistake , I had two entities one over another......could be the same in your case...
Try to select the column using window selection and then erase...see if after selection there is one or many columns....
Your Name
hi, sorry for the late answer, i tryied it but it didnt work. also i was trying to copy a rafter of the house and it says the same thing.
here is a link of it:http://screencast.com/t/VornUOruScn
thanks
hi, can try to untick. please see attached...
shalom...
