Revit Architecture
Revit Architecture
131 Kudos
Post 1 of 4
Printing - Region Edges Mask Coincident lines?
1308 Views, 3 Replies
10-31-2013 07:01 AM
Okay - so I am teachnig a class on Revit and I see a new check box in the setup dialog box for printing...
What exactly does this mean?
I did go to help and this is what it says: "Region edges mask coincident lines. Select this option if you want the edges of masking regions and filled regions to cover lines with which they coincide. (This option is available only if the Vector Processing option is enabled.)"
Yeah - that still isn't clicking in my brain.. (it has been an off day for me already.. :smileyfrustrated:)
So - what are you all know about this? Image attached for reference...
LD
If this helped solve your issue - remember to 'accept as solution' to help other find answers!
You can't think AutoCAD and run Revit.
Email: LisaDragoEE@gmail.com
Lisa,
This allows you to control Masking and Filled Regions and how they work with lines that their edges touch.  The easiest way to explain it is the two attachments.
The edges of the Regions either allow for the lines to plot over top or not to plot over top.
Hope this helps you.
Distinguished Mentor
41 Kudos
Post 2 of 4
Re: Printing - Region Edges Mask Coincident lines?
10-31-2013 07:47 AM in reply to: LisaDrago
Lisa,
131 Kudos
Post 3 of 4
10-31-2013 08:05 AM in reply to: Caddman13
Thank you! That helps a lot... I am sure others will have this question..
Just shows you how much I print!
LD
New Member
0 Kudos
Post 4 of 4
12-23-2014 12:22 PM in reply to: Caddman13
I read somewhere on the interwebs that this worked with crop regions as well, but that doesn't seem to be the case. :smileyfrustrated:
