printing rasta images
1 REPLY 1
453 Views, 1 Reply
when I print my title block the two logo rasta images won't print. If i turn it into a PDF they do. Does anyone know why? I have been through my setting and can't find anything wrong.
1 REPLY 1
luna.ye
Hi Scott,
  1. Select the "Setup" button under the Settings area of the Print dialog box,then pick "raster processing" instead of "vector processing",see if that works.
  2. Select the image and go to the "Properties" dialog box.  At the bottom of the box is "Draw Layer", select "Background" or "Foreground", change whichever is selected,see if that works.
  3. Turn on/off hardware accelleration under Options/Graphics.
If above don’t work, I think you can make a PDF and print it. Or you can try changing another computer or printer, see if that works.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Luna Ye
Product Support
