Hi guys
I'm having some trouble printing from AutoDesk Design Review 2012 to a Xerox 6605 Wide Format with FreeFlow Accxes printer.
When I print, horizontal lines that's not in the original Revit sheet appears across the drawing as show in the attached examples. The number of lines and the space between them seems to depend on what size the drawing is in. I tried to plot an A0 and several lines appeared but when I plotted a A1 just one line appeared in the middle of the paper. I tried to using the 'Turn data into a bitmap before printing' option which seems to work on some of the drawings and the lines dissapear, but then it doesn't work everytime I print. And the one line in the middle still appears on A1 formats. The lines also appear when I plot to pdf.
Hope you can help
Win 7 +64bit
Revit Architecture 2012
Auto Desk Reviw 2012
I don't have a Xerox wide format, but I had the same type of problem with our KIP. There was an updated driver that I had to install on the server for this to be resolved. When Design Review 2011 was release there was a firmware update for the KIP. Might want to look into that also.
Hope this helps you out.
