I was wondering if the printing margins in Revit are set to a certain size somewhere. Basically my issue is that my title block is 1' 11" tall to accommadate a half inch on each side of a 24"x 36" sheet. When I imput that I want to print on a 24x 36 the top and bottom of my title block gets cut off. (see attached screenshot.) This does not happen when I print to PDF, so far only the plotter shows this. Is this a margin issue somewhere, if so how do I fix it. Or is this a different problem I have no idea about?
It could be cause by many reasons,
Just a follow up see if this fixed your issue
My apologies you are correct on the print with no margins option. Could not find the oversized paper option though. But still it worked
Thanks.
