Revit 14 has started printing very light when sending it to our plotter. I have no issues when printing from Revit 12, 13, and creating PDF's. I am using the same line weights with each Revit. Is this a Revit 14 issue or a plotter issue..
I think there was a bug in 2014 that would cause prints to be in a lighter lineweight if you had Thin Lines turned on when you print, although it may have only affected annotation (dimensions, etc.). It was fixed by a later service update. Have you installed all updates?
Is the problem only when printing straight from Revit to the plotter, or does it occur with PDFs as well?
