Hi All,
I just wanted to know if you could please help me with some printing issues that im having on Autodesk Revit 2013.
Whenever I print a file there are thick black lines appearing around the edges of the print, like attached, there is also some strange text appearing on the bottom right hand corner.
I have tried adjusting some of the printer settings in the print setup section but nothing has worked getting rid of these lines!
The lines also appear when I save the file as PDF.
I hope you can help!!
I look forward to hearing from you soon,
Kind Regards,
