Revit Architecture
octavio2
Message 1 of 5 (385 Views)
Printing in Tabloit or 17 x 11 size
385 Views, 4 Replies
01-22-2013 09:39 AM
I have tried to print in Tabloit or 17 x 11 a Sheet, which of course is reduced, but I keep getting large magins and I cannot get a good print that almost "fit" the 17 x 11 sheet of paper.  I have played and changed the settings of both the printer and also of the Revit Plot dialog many times and ahve tried with different numbers and clicked many of the different buttoms in the Revit Plot dialog, but still without success.
This kind of adjustment to "fit" is easy and logical in AutoCAD with the "Fit To Paper" of the Plot Dialog of AutoCAD, but so far seems impossible to achieve in Revit, unless there is a super secret setting there that is not obvious and that I have missed.
What is the way to "Fit To Paper" a Revit Sheet (are the Sheets that we create in Revit 36 x 24?) really well into a Tabloit or 17 x 11 size?
Thanks in advance.
CADastrophe
Message 2 of 5 (363 Views)
Re: Printing in Tabloit or 17 x 11 size
01-22-2013 11:22 AM in reply to: octavio2
I haven't found a way to defeat the obnoxiously oversized margins that Revit adds. You're probably best off setting it to Centered and manually calculating the Zoom %, which in your case would be 44%.
Valued Contributor
ArthurMacLeod5818
Message 3 of 5 (341 Views)
01-22-2013 07:45 PM in reply to: octavio2
Print your Revit sheets to a full size 24"x36' Adobe file. Print your Adobe file to hard copy with shrink to best fit. It won't be exactly half size unless you start with an ANSI D size sheet. It saves you the trouble trying to set a D size sheet to fit a B size.
Arthur
octavio2
Message 4 of 5 (169 Views)
01-20-2014 02:30 AM in reply to: octavio2
01.20.14 This issue of the very LARGE margins when printing on Tabloit 17 x 11 sheets has not been resolved yet in Revit 2014?
New Member
architect.carlos.reyes
Message 5 of 5 (137 Views)
01-21-2014 03:25 PM in reply to: octavio2
I have exactly the same issue.  I think of myself as a reeally good-leveled Revit user,  but still haven´t been able to print directly from revit!
Were you able to solve it?   If so,  I´ll be reeeally happy if you´ll share the big secret!
