If you are using shadows or printing 3-d drawings, make sure you use raster and not vector processing. This may require that you print these sheets as a seperate batch from the rest of the set. The set-up is set in the settings...setup...hidden line views menu drill down of the Revit PDF writer Print Setup menu. Otherwise, yes, it will take forever, if ever to process.
