We print all sizes from 8 1/2x11 all the way to 30x42 on several different
plotters/printers from Xerox, HP and Dell, and I've never seen this before.
It probably has something to do with you using an older printer and a newer
software. However, I've read some posts on Augi about people having trouble
with some HP's. You might want to check and see if there are any new
drivers or even read up on the printer at HP, assuming that you haven't done
any of that. Might be time to invest into a new printer.
wrote in message news:5444750@discussion.autodesk.com...
I print ledger sized check sets on an older HP LaserJet 5siNX. This has
happened on several different projects, and it's sort of a "hit and miss"
kind of thing. It doesn't happen all the time, it waits until crunch time
to act up. The only thing I can think to do is re-print the page that
didn't print correctly.
Most of the time, there are no problems, and I get professional looking,
clean prints, but every now and then a page will seperate itself and print
walls on one page and all of the text and dimensions on another.
The printer doesn't malfuntion with any other software which is why I'm
thinking it may be just a Revit thing. It seems to me that separating the
two prints might be a desirable thing in some cases, but I'd rather it not
do it on its own.
