I have created A1 and A0 sheets using the respective title blocks in the metric version of revit 2013.In the printing dialogue box, I set my settings in zoom to 100%. But only a small part of my entire a1/a0 sheet is getting printed.
hence i tried setting the paper size in the print setup but theres no a0 or a1 paper size available there.
I do not want to use use fit to page option leads to scaling of my drawings. What should i do?
Solved by constantin.stroescu. Go to Solution.
did you make both settings - 1 a and b ?
You have to complete both the Printer settings(a) and Print Setup (b)..
