I'm using Revit 2013 w/ all the current updates (1-3) and hot fixes. When I select a sheet set and send it to the Acrobat print driver, my session hangs up when it gets to 29%. Has anyone found a solution to this most basic of problems? I am working on a large project with multi-trades (Arch, Struct, MEP, and 3 others) and am having many printing issues. At the very least, I need to print sheets sets to a PDF print driver. I tried work arounds but this should be straight forward. Are we beta testing this version of Revit that has been out for more than a year?
I don't use acrobat - not sure if it is that or not... I use Bluebeam
I would suggest trying cutepdf - it is a free pdf maker.
Install that and see if you run into the same issue. If you don't then I would think it is something with acrobat.
LD
